It is currently Sun Jul 06, 2025 10:51 am
PostPosted: Tue Apr 04, 2017 3:04 pm
Hello, I am having work done on the bottom end of my '74 H1 and it appears I will need to replace the transmission top shift fork #13140-013.
Can anyone tell me if this part is interchangeable with the top shift fork on the H2 #13140-048?
I have heard the are the same and the H2 part seems to be less expensive overall.
Thanks!
PostPosted: Wed Apr 05, 2017 3:22 am
seems different, have a look at here;
http://kawtriple.com/mraxl/bulletins/74h-26.pdf
PostPosted: Wed Apr 05, 2017 11:27 am
Thanks for the bulletin info. That does explain some things. But I am still wondering what is the difference between the H1 and H2 top forks and if they are interchangeable? They appear to be identical... Can a H2 fork be used in a H1 transmission?
Thanks!
PostPosted: Wed Apr 05, 2017 3:44 pm
I do not have the answer to your question. However, 2 years ago I replaced all of my H1F shift forks with new aftermarket ones. Though expensive, they seem to work very well.
75 H1
78 CB400II Hawk
78 KE175
PostPosted: Wed Apr 05, 2017 6:38 pm
I have interchange them, with no problems. You just have to make sure the wider ones don't interfere with shifting if you get one.
