I don't know what 3:1 pipe you got, but I have ran Figaroli 3:1 both With Stock cylinders/VM34 and on heavily ported/VM38 on STREET, not only on my dyno. If it is the Figaroli pipe you got, you can look forward to impressive low end Power (better than Stock pipes) And if you have ported cylinders as well, they rev to the moon, but the Power will never be higher than With Stock pipes. Atleast minde did, using zeeltronic, 193 ex duration and VM38's
When running the Stock/vm34 configuration, I used exactly same jetting as I did when running Higgspeed. Hopefully that will lead you into correct ball park.
Jørgen
_________________ ___________________________________________ 72 H2, 72 H1B, 74 H2, 74 H2 Cafê Racer, 71 F8 Bison
