H2RTuner wrote:
Specific oil pump output volumes have been changed many times per model, as we see as example, H2, H2-1, H2-2, H2-3, etc. Each successive number has altered oil volume delivery for the same internal setting.
On the baile, the cable wheel, there are dots past the line, I set my pumps, no matter the pump, at engine OFF, wide open throttle, to the last dot on the baile, to the line on the post, never broke an engine from those settings, ONLY conventional oil, and, I was probably the first person that went as far as to measure the check valve blow off pressures and adjust them to 4.6 psi. I NEVER set my street bikes, stock, to as hot rod as I cam make them, to use premix.
One year at the Castrol 6 hour endurance race in Australia, Hurley ran a stock H2 street bike in the stock 750 class, and used the H2 wheel for the pump, and an S1 pump, ran the whole race on ONE tank of engine oil, no premix, never missed a beat.
Ha thats cheating
, its a stock race you said !!!
, no one was really stock !!!
