It is currently Mon May 12, 2025 12:28 am
PostPosted: Tue Sep 22, 2015 3:36 am
I took apart a 74 h2b 750 motor a found out it had early 71-72 750 cylinders on the 74-75 cases 35 k range and cases were not drilled for the oil to run through the cylinders does this mean the bike was running on premix in the tank?
PostPosted: Tue Sep 22, 2015 4:03 am
Presumably it ran on the H2-B system of oil into carbs, and the main bearings, but not into the intake port floor, as per early H2's.
PostPosted: Wed Sep 23, 2015 4:13 am
+1
