harry_from_vt wrote:
Gm Rotortech, I'm a little late on this thread,I was just wondering if you have a good strong battery in your bike ? The smaller triples don't run good with a weak battery. My bike is a kh 250 with a 350 topend with 400 carbs and chambers.If i don't have a good fully charged battery the low end on my bike is awful.Just a thought.
Harry - good call. When I checked the battery it was below 12 volts. I charged it up and it holds full charge for 24 hours. Not the battery.
Then I started trouble shooting the charging system. I found one terminal that backed out of the connector between the Rectifier and the Regulator. It is a new connector that I installed. The tang on the terminal was not latching inside the connector body. I fixed that and started the bike. Voltage across the battery was fluctuating wildly. The voltmeter could never settle down. I can't believe the ignition worked at all. I got my meter out and checked the stator = OK. The Rectifier is bad and the Regulator appears to be good.
I will put my rectifier question on another thread.
