Hi Jorgen,
Are you using the handheld programer or a computer?
I don't know if it makes a difference I just couldn't get the Zeel to fire past whatever static angle I set in the programer.
So if I set it at 23.5 and I had my mark at 23.5 it fired at 23.5 with the flat curve at 23.5 deg
When I set the static angle on the programer to 27 deg static and a flat curve at 27 deg it fired between the 25 and 30 deg mark.
It would not let me program a flat curve beyond the static angle setting in the Zeel programer.
So I had to change the static angle setting and the flat curve to get it to advance.
I also tried a changing curve and the strobe showed it advancing and retarding to the settings I had programed, which had a simple curve from 15 deg to 27 deg back to 15 deg.
I want to check closely to see if it really is at 27deg
I didn't have the time on that day to play with it any more. I want to try 30deg and see if it fires at 30deg
I will try the way you did it next time and report back!
It may be a few weeks though we are moving our business NOT FUN
