It is currently Fri Jul 11, 2025 3:13 pm
PostPosted: Fri Nov 09, 2012 8:55 am
Possibly a machining mistake in decking, and step cut heads to keep the cylinders out of the trash can?
PostPosted: Fri Nov 09, 2012 9:02 am
I have a stack of copper base gaskets I had made for some cylinders just like that. A lift kit. Yours if you can use them.
PostPosted: Fri Nov 09, 2012 2:49 pm
I'm at a bit of a loss on this one. The cylinders were decked so much the piston is 1mm proud, and the heads are step cut 1mm. I have only seen this when trying to compensate for too much port timing, but the timing is very mild. So it's not making a lot of sense................ :eh:
Everything would make sense if base spacer plates (as I previously stated) were installed in the past (prolly about 2 mm +additional gasket equals 2.5mm total lift from stock).
With a stock head gasket(.5mm) you will get a 1mm squish clearance. The "mild" timing you quote would than be rather "hot".
Have you looked to see if the intake port floor has been lowered?? If it has, its another dead giveaway....
PostPosted: Fri Nov 09, 2012 4:53 pm
I got some background, and it did have a lift kit. The "wrench" said it was too hot of porting, so they took out the kit, and remachined the heads. That is what was throwing me off. Now I need a 1mm spacer, to get the 2mm of lift to get close to a stage two.
PostPosted: Fri Nov 09, 2012 7:02 pm
I suggest you contact Lani. He will make you copper base gaskets (at the total required thickness) at an EXTREMELY good price :thumbup: :
http://www.coppergaskets.us/ContactPage.html
PostPosted: Sat Nov 10, 2012 2:06 am
Thanks for that! I have a PM into Gary Clarke which is making them. Not sure if he has the right thickness i need though.
PostPosted: Sat Nov 10, 2012 9:29 am
Looks like my decking eh? :lol:
