It is currently Sat May 03, 2025 9:49 am
PostPosted: Sun May 06, 2012 11:06 pm
Steve, mcmaster.com (McMaster-Carr) has them, as does msc.com. They are Parker parts, so a Parker distributor in AU should have them or be able to get them for you. The item is "Parker Stat-O-seal".
PostPosted: Mon May 07, 2012 1:21 am
Dumb question, but I asume the 6 mm washer is the one ?
Steve
PostPosted: Mon May 07, 2012 2:11 am
Will the Bonded Dowty seals work just as well ?
http://www.ebay.com.au/itm/10-x-M6-METR ... 3cb62cbeee
Steve
PostPosted: Mon May 07, 2012 6:08 am
http://www1.mscdirect.com/cgi/NNPDFF?PM ... &PMCTLG=00
PostPosted: Mon May 07, 2012 8:46 am
Dale, the one that's highlighted is for 3/8" bolts, but that's the right type, and MSC is a good source.
PostPosted: Mon May 07, 2012 9:02 am
Yes, I know... that is definitely not the one to order!
It just happened to be the reference I used to get the whole page to display.
Did not intend for anyone to pick up on that highlight...
PostPosted: Mon May 07, 2012 9:42 am
It looks like the Parker number is 610-1543-6. The "43" part can also be 44 (different color) or 02 (low carbon steel instead of 4130 steel). Maybe this will help you find them locally.
PostPosted: Mon May 07, 2012 3:34 pm
Jeggs carries them here, though not cheap. Are there any auto "speed shops" around there? NOTE: these are not as inexpensive as the ebay ones!
PostPosted: Thu May 10, 2012 12:27 am
I end up getting some bonded pressure seal washers from a local company for $1.00 each (oz seals). They have rubber on the inside. They are holding so far. I rang around but noone is interested much in selling 6 washers. Parker did not even call me back.
Steve
PostPosted: Thu May 10, 2012 8:06 am
Right, Parker wouldn't, but their dealers should have them in stock. Usually the bearing and power transmission supply places have them. Anyway, good that you found something that's working.
