It is currently Tue May 06, 2025 4:30 pm
 Post subject: Re: hard starting H1
PostPosted: Fri Oct 28, 2011 8:52 pm
How would you do that? Just interested to know............!
PostPosted: Fri Oct 28, 2011 10:17 pm
Based on how quickly it returns to idle.. :?:
PostPosted: Fri Oct 28, 2011 11:44 pm
It's not any one thing. You just need alot of experience with triples with rubber seals then switch to labs. You will notice that the bike doesn't seem to rev as quickly off idle. Not as snappy. But it's a very fine difference with a good set of lab seals. Most people never notice because their rubber seals were bad for so long even a bad set of labs runs great by comparison. On an RD the clearance is .0015", most labs you see for a triple are around .006". The H1 and S series don't seem to have the same problem as the H2 as their seal area is wide for both seals. The benefit on an H2 is that it won't run worse over time due to degrading seals.
PostPosted: Sat Oct 29, 2011 1:47 am
Make sure the distributor timing is correct. With one cylinder at near top dead center, make sure the distributor rotor is actually opposite the contact for the same cylinder coil. If not, remove the brake lever, loosen the sidecover and slip the cogs until it is. There is two timing points to watch... the actual spark timing and this... the cylinder timing.
PostPosted: Sat Oct 29, 2011 8:36 am
Chris,
Keep at it. Eventually you will find one dumb item that you will never forget and the bike will be easy to start.
My completely original, never rebuilt, H1D used to start by the 3rd kick no matter how long it sat.
PostPosted: Sat Oct 29, 2011 8:40 am
Not sure how long the bike was apart, but did you clean the carburetors before installing? If the bike bike sat more than a month, the fuel leftover in the carbs will already be turning back into the dead dinasour that it was many years ago.
PostPosted: Sat Oct 29, 2011 9:00 am
Dayle, his '74 H1 has the "distributor" built into the alternator, on the left, assuming the engine is still a '74. I think you're talking about an early H1 high voltage distributor.
PostPosted: Sun Oct 30, 2011 10:19 am
Years ago i restored a kawasaki S2 I fought i had put the engine back together correctly but for two days could not fire the old girl up until i had realized i had used car ht leads changed them for bike leads fired up second kick
Gary
PostPosted: Sun Nov 06, 2011 9:50 am
Hi all
I just got power back after a full week of being in the dark and it being cold what a freak snow storm we had.
i crossed the blue and green wire fixed it started first kick.
Thank you all for your input.
Chris
