Quote:
I have the throttle marked and the problem areas are bogging off line, 1/8 to 1/4 throttle seems to burble a lot there, and then 1/2 to 3/4 Im having trouble deciding what needle position is best, not a lot of change when I change clip position, I do know when its to rich and to lean but there seems to be a two needle clip positions that work the same, thinking I should stay in the rich side of the settings,
The main right now is 310 and way to rich.
Demus
Of course my bike is piston port, squish heads, zeel and VM34's with UFO's.....but
1) I had a slight bogging off the line, could rev it and a slight delay......I also had to hit the choke button a couple of times when taking off when cold.........went from 15 pilots to 17.5 (UFO'd, yours will be bigger...like 30 to 35)...........fixed that, major improvement.......if it's peaky and bogs off idle, richen that up
2) I had burble and rich spot at 1/8 to 3/8 throttle........that is more the needle jet than the needle as the needle jet is the FIRST 62 percent of throttle opening from 1/8 to 3/4........it's in the mikuni manual VM supertuning, a chart........with my stock motor at first I had P6.......changed to a P2 and transformed the bike........then I did the squish heads and it was rich again.........went down to a P-0 (UFO'd though).......I tried a 0-8 and did about 1/2 mile, that was way lean and you could tell.......went back, tried the P-2's and rich....put the P-0 back in........perfect........I would go smaller than P-5 or P-6........you will know if it's lean instantly, go home and up them
3) Was on the 6DH4 needle clip 2..........just felt like it needed to be very slightly richer earlier.........put in a 6DH3 needle, clip 2, the taper starts earlier........that one drove me nuts trying to figure it out with the EXCEL table......very nice improvement with the Zeel advance (it will lean them out when advancing some as you know)........I got a 6DH3 and a 6DH7 and tried both........I like Neville suggestion on his needle choice and would like to try that.........but I don't think I need to
4) I think you are way rich on the Main Jet.......I tried a 260.......then a 240........then a 230 for a while........went down to a 220 and it rip's........have not seized it, so I guess it's OK.......(Your Bike will need bigger......maybe a 240 guessing)
5) I did a lot of this on a flat curve at first, then had to do it all over again with the Zeel........I also tried the low advance at idle, bike did not like it...........23 degrees at 1800........up to 26 at 3000.........down to 23 at 6000 or so, then on down......was good for jetting on MY bike
THX Phil
