It is currently Sat Jul 05, 2025 10:52 pm
 Post subject: Paint Question
PostPosted: Wed Aug 10, 2011 8:34 am
For you pro painters out there: is it possible to remove the Kawi factory clear, and re-apply without wrecking the original paint? I know it sounds stupid, but I would like to restore the original paint rather than re-spray. I used to be a Mustang fanatic and I remember seeing a before and after shots of paint restoration that were almost impossible to tell from original. Any thoughts? Oh, and just to complicate things, I would be air brushing the stripes...but I know that can be done successfully.
Thanks for any input.
 Post subject: Re: Paint Question
PostPosted: Wed Aug 10, 2011 8:41 am
Short answer, no, due to the type of paint [amino alkyd enamel - essentially a "one-pack" finish] and the age of the original paint. While it is a clear over base procedure, [originally] , it is very thin. The Mustangs were probably an early version of current two-pack technology.
PostPosted: Wed Aug 10, 2011 8:44 am
Thanks, can it be sanded off (by hand)?
PostPosted: Wed Aug 10, 2011 8:48 am
The clear? - not without damage to the basecoat. Sounds like there is a paint-job in your future! Probably worth it with modern clear-over-base 2-packs.
PostPosted: Wed Aug 10, 2011 9:05 am
Thanks Rod. I know a paint job is easy enough these days, but even the best of them look "thick" and unoriginal - the clear bulges over the decals which are much thicker than original water slides.. I might try air brushing over the clear (to fix the flaws and faded stripes) and then put a super-thin final clear.
Thanks again for the advice!
PostPosted: Wed Aug 10, 2011 9:11 am
Let us know how you get on - patience is the key. I remember fitting a few of those early KAWASAKI tank transfers, they weren't waterslide more like a soft transfer, softened in a special solution - bit of a heart-stopper :lol: Good luck!
PostPosted: Wed Aug 10, 2011 9:18 am
You could buy the decals and paint from Kawi right? I saw some NOS decals on eBay once...but figured they would be pretty brittle by now. A friend of mine has a set for blue H2 which he offered me for nothing, so I might give those to my painter -- along with a bottle of Scotch. :lol:
PostPosted: Wed Aug 10, 2011 9:22 am
Oh, I thought Rod was saying the transfers were softened by a special solution.
PostPosted: Wed Aug 10, 2011 9:35 am
The scotch just might do it!! You could buy the transfers back in the day, I haven't seen any for years. They had backing paper both sides, the last step was to EASE the top layer off and let 'em dry completely before the clear. There was a knack to it, wonder if I can remember what we used to soften them [wanders off, scratching head.....]
