It is currently Sun May 11, 2025 9:03 am
PostPosted: Wed Oct 30, 2013 10:59 pm
These are for the shift linkage for most if not all of the Triples. I currently can't find NOS (pn 318N0800), but judging by the prices for NOS RH nuts, they wouldn't be too reasonable if they were available. I've found JIS right-hand but not the one in the title. Anyone have a secret source? I'd like to pick up a handful of them for all my Triples.
PostPosted: Wed Oct 30, 2013 11:06 pm
Darrin, McMaster-Carr has left handed M8x1.25 nuts in 18-8 stainless for a buck each:
http://www.mcmaster.com/#93510A125
There are probably other options there too.
PostPosted: Wed Oct 30, 2013 11:56 pm
Yes, I saw that Jim, but for the shifter, I would prefer it in JIS spec, the difference being JIS is 12mm flat-to-flat width, the other is 13mm. It's not a big difference in itself, but when cinched up to the fore and aft shifter connectors, the 13mm will stick out a bit. If I absolutely must, then I will, but I wanted to see if someone knows a source for the JIS bits. Thank you though. :wave:
