Dear all,
I own a 1974 H1 that is currently in pieces. I am starting the restoration and while I clean up all of the engine parts, I want to have the frame repainted.
I was wondering if anyone knows of a reliable paint shop around the Central NJ area that does good jobs. I would like somebody that has experience painting Motorcycle frames so I do not have to worry about paint getting into places where it should not get (bolt holes, steering head, and so on) but all nooks are covered.
I was thinking of getting the frame powder coated and I was wondering if I would still be able to see the frame serial number through the powder coat?
Further, what is the correct color for the frame? Just glossy black?
Before I have the frame painted I will need to straighten the rear support for the turn signal. As can be seen from the images, probably the bike fell on its side and the turn signal stem twisted the support. The metal is pretty thick and there is not much space between the sandwiched parts. Any suggestions as the best way to straighten the support? Hammer it? Heat it first?
Finally is there any way of removing the steering head sticker? I know there are places where I can buy replacement and I will do that, but if at all possible I would like to save the original.
Thank you,
claudio
