It is currently Tue May 28, 2024 2:05 pm
PostPosted: Tue Oct 30, 2012 12:25 pm
I located a Kawasaki dealer who reports he is showing availability of some new old stock, pending verification inventory is really there. If there is interest I will post the dealer's contact info.
Regards, Rusty34
13001-050 piston, std 3 $103.77
13008-042 ring set, std 3 94.55
13024-049 ring set,.0.040” O.S 6 71.29
13025-045 ring set,.0.020” O.S 2 63.59
13027-049 piston,0.40” O.S 1 114.46
13044-027 brg-n,71ktv012 1 1 27.82
13080-004 rubber cap 5 5.34
13088-028 plate-clutch friction 18 20.04
13091-009 holder cl. Spg6.5x20x2 21 3.40
13116-011 pusher-clutch sprg plt 1 29.74
13118-008 outer, clutch release 2 21.74
13130-027 2nd gear-drive shaft 1 59.13
13132-025 3rd gear-drive shaft 3 89.07
13133-024 3rd gear-output shaft 2 109.52
13134-011 4th gear-drive shaft 1 55.69
13135-015 4th gear-output shaft 1 103.46
13136-035 top gear-drive shaft 4 83.11
13140-048 fork-selector, top 1 111.88
13144-036 eng sprocket 16t 1 28.44
54011-058 clutch cable 1 49.96
23006-024 rim head light 2 95.84
23007-034 sealed beam 2 104.78
23016-006 lamp assy. Pilot 2 17.05
23006-035 rim head lamp 1 52.16
21119-012 unit A 1 391.42
21120-005 unit B 1 296.71
21076-011 yoke assy 1 868.16
21156-002 plate-pick up 4 12.27
21061-014 rectifier 2 53.62 (used with #21072-006 regulator)
25005-073 speedo 1 185.94
25005-019 speedo 1 295.35
23027-029 case tail lamp 1 39.48
3 H2's, all stock
H2B, converted to H2C
75 Paint & Decals by Brian H
75 Euro Seat by Tony O'Connor
PostPosted: Tue Oct 30, 2012 1:46 pm
run for gear box parts guys :mrgreen:
PostPosted: Tue Oct 30, 2012 6:05 pm
I spoke with the dealer again and he is interested in an offer for the entire lot. What do you think would be a fair offer?
Thanks, Rusty34
3 H2's, all stock
