It is currently Thu Oct 31, 2024 6:44 pm
PostPosted: Fri Jun 15, 2012 8:57 pm
I was checking electrical and I could not get the Neutral lamp on the instrument panel. Checked wiring and connectors and swapped bulbs. I finally found out that the bulb is good and the socket works. The switch was open all the time. I pulled it out and took a look. This is what I found:
It may not be obvious but there is supposed to be a copper "wiper" that contacts a screw on the shift drum when the trans is in neutral. It took me a few minutes to sort all that out. Then I went looking in parts bins for something to make a new contact/wiper out of. I found the copper spark plug connector also shown in the picture.
A little cutting and a little drilling and hardly any bending and this was born:
Here it is from the other view. It shorted against the case on the first try but I made a small adjustment and it worked very well.
I did not even check availability. Maybe these are only $1 but I had that creative urge so I just followed through. Maybe this will help someone in a pinch.
Rotortech
Indianapolis
1974 S3
PostPosted: Fri Jun 15, 2012 9:15 pm
You did good!
I made a contact out of a paper clip.
PostPosted: Fri Jun 15, 2012 9:27 pm
if you can't neutral on a triple..... :lol: :lol: :lol:
PostPosted: Fri Jun 15, 2012 9:57 pm
It's a little harder on an S3...
PostPosted: Fri Jun 15, 2012 10:21 pm
Don't they have 2 gear lock outs?
PostPosted: Fri Jun 15, 2012 11:36 pm
ha isnt that the same one for H2s and dosnt someone here have repos of them for a good price, and very creative on your making one :clap: , but I feel the first time it hits the contact it wont bend back ?,
PostPosted: Sat Jun 16, 2012 6:10 am
Same concern here. I shifted it up and down several times and it seems to work without difficulty. I will need to put a few thousand more shifts on it to know if it will hold up. :lol:
mraxl - I like the paperclip idea. My shift drum has a slotted screw installed in the OD. The slotted head is what hits this contact. I wonder if the slotted head would chew up the paperclip loop.
John - what does "two gear lock outs" mean?
Rotortech
Indianapolis
1974 S3
PostPosted: Sat Jun 16, 2012 6:18 am
I did this about 20 years ago and it still works.... don't ride much though. Can't remember how I configured it.
The repo replacements don't come with the metal contact.
PostPosted: Sat Jun 16, 2012 8:25 am
That doesn't sound very useful. Am I missing something in what you said?
Rotortech
Indianapolis
1974 S3
PostPosted: Sat Jun 16, 2012 8:54 am
http://www.hard-to-find-parts.de/pd-204 ... tegoryId=8
