It is currently Tue May 13, 2025 2:38 am
PostPosted: Sun Apr 29, 2012 11:55 am
Dumb question, I know but my KH500 came in bits and I don't know where Ignition Box A is mounted. I think B is adjacent to the voltage regulator on the left side of the bike near the battrery.
Thanks,
Kevin
PostPosted: Sun Apr 29, 2012 12:11 pm
KH500 Voltage Regulator/Rectifier & A Ignition box
PostPosted: Sun Apr 29, 2012 1:16 pm
Sorry - I got confused between A and B - I need the location of the B Box.
Thanks,
Kevin
PostPosted: Sun Apr 29, 2012 1:21 pm
Follow the yellow wire from the "A" unit.
PostPosted: Sun Apr 29, 2012 1:39 pm
I am trying to understand where it would be located if it was fitted to the bike. I have the A box mounted but I cannot seem to find the mounting points for the other box. The yellow wire is disconnected.
Thanks,
Kevin
PostPosted: Sun Apr 29, 2012 2:18 pm
I understand from others that on the KH500 the smaller unit mounts on the other side of the plate from the larger one.
PostPosted: Sun Apr 29, 2012 10:03 pm
I tried to mount it tonight but although the hole spacings are the same on the plate to mount the B Box behind the A Box it bangs up against the airbox. However, maybe KH500 B boxes are thinner than the H1E/F boxes?
Kevin
PostPosted: Mon Apr 30, 2012 12:07 am
No, the boxes are the same, other than wire lengths. I don't know why you don't have room for the smaller one on the back.
PostPosted: Fri May 04, 2012 7:39 pm
I discovered that it actually mounts just in front of the battery on two tabs on the left fron edge of the battery box.
Kevin
PostPosted: Sun May 06, 2012 8:44 am
I got a pile o parts I have to reassemble. I figure as long as it don't look like this when I'm done I did a decent job. :lol:
