It is currently Mon May 12, 2025 6:11 pm
PostPosted: Mon Apr 23, 2012 8:22 pm
Which one of these is the correct color? Or is there that much variation?
http://www.ebay.com/itm/KAWASAKI-S3-400 ... 39&vxp=mtr
http://www.ebay.com/itm/A12-51001-089-2 ... f8&vxp=mtr
Edited, got the first pic to link...
Last edited by ThreePipesSmokin on Wed Apr 25, 2012 7:00 am, edited 1 time in total.
PostPosted: Mon Apr 23, 2012 9:03 pm
Depending on the camera, lighting, flash/no flash etc. etc, they "could" be the same colour!!
PostPosted: Tue Apr 24, 2012 2:25 am
As with ALL Kawasaki paints from the era, each batch, could, and often would be a different shade to the rest, the greens are particularly bad for this, H1d/e are a lore unto themselves, as are S1b and S3a, The H2 Greens tend to be pretty uniform though, and as Rod points out, the lighting and type of photo will never give an accurate version of the colour. Oh, this particular Green is one of the versions that will fade all by itself even in a closed cardboard box :shock:
PostPosted: Tue Apr 24, 2012 4:31 am
I had a green 75 S3 new and the paint darkened up in just a few weeks
and the dealer replaced it under warrenty with a red set
Brec
PostPosted: Tue Apr 24, 2012 5:14 am
Modern 2-pack clear over base paint systems are a lot better than the old type paints Kawasaki used back then, and any colour is able to be matched! :thumbup:
PostPosted: Tue Apr 24, 2012 5:21 am
definitively my favorite S3 color :thumbup:
PostPosted: Tue Apr 24, 2012 5:57 am
So, as I suspected, they're ALL Spartacus! :lol: Since I'm not doing a concourse restoration it really doesn't matter if it's "right" but these two seem to be at the extremes. For some strange reason I'm drawn to the dune buggy metal flake overload! :shock: It's bright and fits with the era. And I have a pretty close match with the Duplicolor MetalSpecs rattlecan. This stuff gives a different shade depending on the color of the primer, a flat black primer gives almost a match for my H1E while light grey primer comes pretty close to the pic above. I just hope it doesn't cause difficulty keeping an even shade across the whole tank. I think Florida Steve had good results with this paint so it's worth a try. Of course if I don't like how it comes out, I won't put the decals on until I like it! :mrgreen:
PostPosted: Tue Apr 24, 2012 10:29 am
Definitely go with the Bass-Boat Sparkle...... The other tank was probably much brighter when new and I think the fading RB mentioned is the culprit.
You don't HAVE to wear the bell-bottoms and the polyester shirt but it would make the tank more authentic...
tim
PostPosted: Tue Apr 24, 2012 11:10 am
tim
He wears bell bottoms and polyester everyday anyway....... :P
PostPosted: Tue Apr 24, 2012 11:23 am
I may have to dig out my leisure suit! :e11 :e9
