While I am awaiting some other bits and pieces I decided to verify the function of the check valves on the oil injection lines.
For reference the bike is a 1974 S3 and the lines appear to be originals.
I saw the beautiful pressure checking block in the How To section on Check Valves. I don't have enough of a machine shop here to whip one of those out so I used some hose and a vacuum pump with a gauge to do the trick.
Here is the set up. I used one of the banjo bolts, two orings, a piece of 5/16 hose and a clamp.
Here is a close up of the way I attached the hose to the banjo bolt. Crude, yes?
When I attached the hose I grabbed the hose in my fist and pushed down on the bolt with my thumb while tightening the clamp. Then I pumped the vacuum pump a little. I heard some air gasping and held the banjo bolt to my ear to verify that it was leaking there. On the second try - no air leak. The gauge showed 5 inHg and it was steady with no leakdown. So I tested the other two check valves and they are all the same - 5 inHg. That is equivalent to 2.5 psig. I feel confident with that number and will go ahead and use them as is. I was paranoid about oil control and did not want to risk taking these apart.
I wanted to share this with others who might be wondering about their check valves. Even though my bike is the S3 you could use this set up for any model to test cracking pressure and leakdown on check valves.
