It is currently Wed May 07, 2025 4:12 am
PostPosted: Fri Mar 23, 2012 10:02 pm
I admit I did a weak attempt of searching the forum so far.......but in the interest of time.......does anyone have any pics showing the cables and harnesses routed near the steering neck and the wiring in the battery area.....links to the thread would be fine......PO definately didn't put back to stock and I would like to make a descent attempt.......in the mean time i'll try some more searching....TIA guys.
Mike
________________________
2006 Honda Goldwing
1995 Yamaha Vmax VMX12G
1986 Kawasaki KDX200
1974 Kawasaki H2 750
PostPosted: Sat Mar 24, 2012 8:45 am
This should help for under the tank...
http://kawtriple.com/mraxl/tips/cableroute/cablerouting.htm
PostPosted: Sun Mar 25, 2012 7:29 am
Thanks Three. I've seen that page over the years and is definately helpful.
Nobody else has any pics they took during thier resto, eh?
Mike
2006 Honda Goldwing
PostPosted: Sun Mar 25, 2012 9:35 am
OK. I've got four cables:
Throttlr
Choke
Tach
Clutch
Maxrl's Cable Routing Pics:
750 (top pic)
I see three cables. It's obvious two are the throttle & choke. The third makes since to be the tach (cause it's down on that motor side). I would then think the fourth is the clutch and would be on the other side of the neck (it's on that side of the motor).
H2B/C (shot from front/LH side)
Only shows main harness. Maybe cable wasn't run just yet?
H2B (further down-shot from RH side)
Only shows two cables.
Am I correct in routing as noted in the first pic? Three cables on RH side and clutch on LH side? Makes sense that way.
Edit: Tach for Speedo
Mike
2006 Honda Goldwing
PostPosted: Sun Mar 25, 2012 9:45 am
Yes
PostPosted: Sat Mar 31, 2012 12:53 pm
Bump......
No one has any pics of the wiring in the battery box area?
Mike
2006 Honda Goldwing
PostPosted: Sun Apr 01, 2012 1:25 pm
I used old road test for proper location of wiring under the seat and other areas
Do you still need a photo?
PostPosted: Wed Apr 04, 2012 7:16 am
Yeah. That would be great if you have one available. Unsure what your reffering to specifically as "Old Road Test". I presume out of a magazine or something?
Mike
2006 Honda Goldwing
PostPosted: Wed Apr 04, 2012 11:45 am
I'll take some tomorrow and post of the battery and seat area.
PostPosted: Sat Apr 07, 2012 1:53 pm
Sorry for the delay BUT here they are.
