I know some here will just say "yeah, right, whoppie for you, Tuner", but many years ago, when I worked in a Kawasaki service shop, I built a tool, as I always do, that inserted in place of the removed baffle, and literally screwed it one direction to expand a holder. When the holder was in place and tight, the diverter sections in the mufflers could be checked for coming loose inside the pipe bodies themselves. They are only spot welded in place, and, they do come loose from time to time. And, it helped determine if the muffler needed to be warrantee'd, replaced, or, the baffle, etc.
Later, when I had my shop in Merced, a fellow brought me a CR500 with aftermarket pipe and spark arrester, ran great with no muffler/arrester. Put the mess back on, ran the same great for a short distance, then, stop city. Muffler was fine, arrester was fine. When I stuck a broom handle up the rear of the arrester, the thing ran great again, for a short time, then fell flat on its face again. Finally took the mess apart, section of the arrestor was open when the broom stick pushed it forward, but exhaust gas forced that plate back when the thing ran closing off ALL exhaust flow. I finally just put the plate back in the right place, and added both stitch welds and screws to hold the plate. It worked good enough for the guy that owned it to go out and fall off at high speed in the boonies, causing him to sell it for a greatly reduced cost....to me. One day, I'll find a nice little 125 cafe Honda chassis of some kind, and put that CR engine in it, just for nice, street riding fun.
