It is currently Wed Apr 30, 2025 1:17 pm
PostPosted: Tue Apr 14, 2020 1:23 pm
Hey guys, working on the rear brake on a S2. Two questions:
1) The cable is in really good shape - after some evaporust soaking, the spring came back to life! What is the ideal cable lubricant? spray, grease,? i can't imagine that wd-40 is at top of the list, but maybe.
2) The wire casing on the switch is brittle. What is the real way to fix? wrap in e-tape? or is there long heat shrink wrap (i only have ever seen really short pieces)?
running... '78 KH400, '07 KLR. In a state of repair.... '72 S2.
PostPosted: Tue Apr 14, 2020 1:55 pm
For the wiring, I'd clip off the bullet connectors, leaving as much wire as possible, replace the black sleeve, and install new bullet connectors.
An easy way to lube a cable like that is with a spray grease with a little tube on the nozzle, and one of those little adapters that clamps to the end of the cable and has a rubber fitting you stick the little tube in.
You can also mix some grease with varsol (aka mineral spirits), hang the cable up, and dribble the liquid grease in.
Some guys prefer dry lubes like molybdenum disulfide.
PostPosted: Tue Apr 14, 2020 2:54 pm
http://www.vintageconnections.com/
There’s other places too.
PostPosted: Tue Apr 14, 2020 3:22 pm
Thanks Jim. I have that cable spray adapter thingy! So I'll use spray grease.. Wasn't sure if there was a 'preferred' kind or not. I have a can of white lithium grease as well as a can of liquid wrench chain lube-- it says ok to use on wire cables, but I dunno if it is suitable for this cable...
Copy THAT! Good link to all the sleeves and connectors and stuff! THANKS
funny, it's kinda crazy that the bullet connectors are 20¢ each... :shock:
PostPosted: Tue Apr 14, 2020 3:58 pm
I bought a big bag off eBay much cheaper!!...... you get what you pay for :(
They worked but are delicate
