It is currently Sat Jun 01, 2024 6:39 pm
PostPosted: Sat Mar 16, 2019 3:05 pm
The humidity in Hawaii promotes rust... quickly. I've replaced several steering head bolts (H1, H2, KZ900) and the new bolts started rusting within a couple of years. I keep my bikes covered too.
Somewhere on the 'net I found information about a company in the UK that makes these bolts and many others in stainless steel. I bought two steering head bolts. The seller discounted the shipping, I don't remember the details, I think I paid shipping for one item when I bought two.
A stainless steering head bolt costs $33, expensive yes but it looks fantastic and I don't forsee ever changing it again.
The vendor name is Classic Bike Fasteners on e-bay.
https://www.ebay.com/usr/classic_bike_f ... 7675.l2559
PostPosted: Sat Mar 16, 2019 6:10 pm
Here are the before and after pics
PostPosted: Sun Mar 17, 2019 6:50 am
Looks great. :thumbup:
PostPosted: Sun Mar 17, 2019 8:16 am
Yes, thanks Mike, that's good information. I don't think it's expensive either. They're not in mass production.
PostPosted: Sat Jun 01, 2019 4:49 pm
Hi Mike,
Not far from the ocean, I struggle with routine moisture issues as well. Forward facing chrome or raw metal takes the brunt. The moist salty air clings to those surfaces after a ride and then the rust has it's fuel. The brake rotor edge, fork tubes, throttle cable and brake line ends, turn signal stems, etc..
A small light placed on the floor under my bike cover did the trick for me. Don't use an LED. You want the warmth, not the light. I use a 60 watt bulb in one of those aluminum clamp type fixtures. Just a few bucks at HD, it keeps it warm/dry enough under the cover to fight off the rust from starting between bike rides and polishing/waxing sessions.
PostPosted: Sat Jun 01, 2019 6:16 pm
Good advice on the light bulb.
It's amazing what it will do. Found out when I lived in Prince Edward Island in the 70s
I had a problem with my water pump, in my un-insulated old farmhouse basement, freezing in Winter.
A friend told me to place a 60-75 watt bulb next to it and it never froze up again.
Just a bit of warmth made a huge difference.
