Finally starting on the old S2 http://www.kawi2strokes.com/forum/viewtopic.php?f=13&t=13232 |
Page 1 of 3 |
Author: | Stev-o [ Mon Jan 01, 2018 9:05 pm ] |
Post subject: | Re: Finally starting on the old S2 |
Subscribed. I also have an S2 I will be restoring later this year |
Author: | triple cranks [ Tue Jan 02, 2018 4:27 am ] |
Neat little bike! Good luck with the build. ![]() |
Author: | 2stroke [ Wed Nov 06, 2019 6:53 pm ] |
Well screw photobucket. My images are all gone. Imgur here I come. I painted the frame with many coats of rustoleum epoxy paint. It is what it is. Cant afford powder coating or a professional job but its easily the best bakyard job Ive ever done...stripped the frame completely. The bonus is that this bike will now live in a climate controlled garage previously converted into living space, which I turned into a shop. Before all my stuff had to sit outside and anything I did to my bikes appearance wise went to crap. Again, Im not going for a "restoration". Just a build so to speak. I plan on thrashing this thing, and having "correct parts" or whatever is just not important to me. Here is the S2 frame in my shed along with my KX400 frame. I used VHT epoxy on the KX. I guess it will be a comparison of sorts. The Rustoleum "handled" better during application. The VHT has a miniscule orange peel effect, but it serves to tone down the glossiness I think, which I sort of like. Only one coat on the KX now, Ill sand out the imperfections and hit it with many more. ![]() I stripped down the swing arm and I have to say, the welding on it is kind of crappy and inconsistent. Not that Im gonna do anything about it, just sayin. Ive only been welding with any regularity for the last 2 years at my new job, and I could do better by far. ![]() One if the welds on the lower shock mounts looks okish, the other side looks sloppy as all hell, like they missed the joint a little. I might actually beef that one up. ![]() If I get some time, I will try and restore the pics from this thread at least if I can still edit the old messages which Im not sure about, or maybe Ill just make a post full of pics from earler stages. Yeah thats what Ill do. I actually have 3 winter projects, we'll see how far I get!!!!!!!! (KX400, S2, and XT500) |
Author: | RODH2 [ Wed Nov 06, 2019 6:57 pm ] |
I haven't actually seen too many broken welds on old Triples frames, regardless of how they look! ![]() |
Author: | 2stroke [ Wed Nov 06, 2019 7:04 pm ] |
PICTURES from earlier in the process we'll call this before ![]() ![]() A broken wire I found in the stator and fixed. ![]() The engine down some of the way. Mostly did this to inspect it. Had trouble missing 2nd gear sometimes. I actuall took the find neutral helper detent balls out of the shaft which sounds nuts, but we'll see how that goes. ![]() Heres the engine put back together. I put new pistons and rings in. I will work on the appearance before I put it back in. ![]() Cheers all! |
Author: | 2stroke [ Wed Nov 06, 2019 7:07 pm ] |
RODH2 wrote: I haven't actually seen too many broken welds on old Triples frames, regardless of how they look! ![]() Yeah appearance isnt really important. We have a guy at work and he does "cinemax" welds....they look good, but theres no penetration. ![]() |
Page 1 of 3 | All times are UTC - 5 hours |
