It is currently Wed Jul 09, 2025 11:50 am
PostPosted: Sat Oct 01, 2011 1:15 pm
hi all i have just got my frame back from the coaters and where are the important points i need to remove said coating from to regain the grounding etc.
and once cleaned off, presumably a blob of dialectric grease to ressist corrosion.
thanks mark
PostPosted: Sat Oct 01, 2011 1:53 pm
Lacking specific model info, in general, any point where a wire or ground lug is attached to the frame. On some models the coil mounting lugs serve as coil ground.
PostPosted: Sat Oct 01, 2011 2:09 pm
also the motor mounts? Unless you have a ground strap.....
PostPosted: Sat Oct 01, 2011 6:01 pm
sorry :oops: this is on a 73 H1 ,
PostPosted: Sat Oct 01, 2011 6:28 pm
Ignition coil mounting lug surface, engine mounting surfaces (as JA mentioned), CDI black wire attaching surface, battery (-) frame surface, not excluding those mentioned above.
PostPosted: Sat Oct 01, 2011 10:10 pm
thanks i will get my chisel out :lol:
cheers mark
PostPosted: Mon Oct 03, 2011 5:41 am
Harbor freight has a tool especially for that for just a few bucks. Will be going down to get one shortly.
H2C needs coil attachments done too? should imagine only one hole per coil needs preparing....
PostPosted: Mon Oct 03, 2011 5:44 am
yes
PostPosted: Mon Oct 03, 2011 12:52 pm
Having just powder coated my frame (and now with an interesting issue as mentioned in a thread with Cody) I DID all the frame points where electrical connections are - coils etc. The one thing I did not do is the Motor mounts - and I want to strap that and see if it makes a difference on the strange issue.
bb
PostPosted: Fri Oct 14, 2011 2:55 pm
Was talking to the powder coater today, I mention the issue about ground wires to frame where the frame has been coated. He said you may not need to scrape off the paint because if using screws then the frames female threads were protected from coating, is bare and should ground the screw with the wire. I will be cleaning out the threads on the frame will good and see if that really does work before scraping the powder coat.
