It is currently Thu May 01, 2025 11:47 am
 Post subject: Oil pump leaking
PostPosted: Wed May 06, 2015 7:09 am
I have installed new aluminum and then stato seal o ring washers and in both cases the following day, under inspection injection, oil has leaked to the extent that it has reached the side cover drain hole. The seal surfaces are in good shape. What have I overlooked?
 Post subject: Re: Oil pump leaking
PostPosted: Wed May 06, 2015 7:34 am
Stuff a paper towel or tissue around the pump and leave it overnite so you can determine exactly where the leak is coming from.
PostPosted: Wed May 06, 2015 2:57 pm
Thanks, I will try to locate the leak.
