It is currently Wed Apr 30, 2025 6:19 pm
Post new topic Reply to topic  [ 151 posts ]  Go to page Previous  1 ... 6, 7, 8, 9, 10, 11, 12 ... 16  Next
 Post subject: Re: 1972 H1-B
PostPosted: Mon Jan 15, 2024 10:57 am
My carbs were off the bike when I received it, I take it that the carb with the vac line is the center carb and the other 2, LH or RH doesn't matter? I didn't blast the cases, went with a good hand cleaning and a little polish in the visible areas. I'm about to button it up, ordered some Loctite 620, would a couple drops on the upper case be sufficient? I watched the video multiple times, I have rubber seals, so none needed in that area?
Thanks, Buddy.
PostPosted: Mon Jan 15, 2024 12:52 pm
Originally the carb with the vacuum line was on the right cylinder. Put it where you want to though. I have that one on my L cylinder so I can easily pull off the line and put my finger over the port to run the gasoline out of all three.
PostPosted: Tue Jan 16, 2024 10:23 pm
Going through the tranny as per the transmission repair thread on the resource site, everything seems to be in spec. It was mentioned that I need to bolt on the clutch basket and sprocket before going through checks?? I didn't see anything in the thread about that.
PostPosted: Wed Jan 17, 2024 12:25 pm
It is mentioned in a different section... http://kawatriple.com/tunerwisdom/tran_shim.htm
PostPosted: Wed Jan 17, 2024 3:22 pm
Thanks, I'm going back through it with the advised process.
PostPosted: Thu Jan 18, 2024 2:35 pm
Any recommendations for clutch plates? Vesrah, EBC, etc.. Where can I find the specs on the resource page for checking clutch plate and springs wear limits? I couldn't find them.
PostPosted: Thu Jan 18, 2024 4:36 pm
The Kaw shop manual and the Triples Maintenance manual, both on the resource site, have those specs,
PostPosted: Fri Jan 19, 2024 7:50 am
https://kawatriple.com/servicelimits.html
PostPosted: Fri Jan 19, 2024 9:47 pm
Thanks, just what I was looking for, I'm definitely going to throw in some new plates, I've ordered a few things from Jesse Bikes, he has plates for $60 but doesn't specify brand, has anyone used these plates or would I be better off with a familiar name brand?, rather buy from known supplier.
PostPosted: Sat Jan 20, 2024 7:51 am
You won't find a better supplier than Jess!
