It is currently Wed Apr 30, 2025 7:47 am
Post new topic Reply to topic  [ 151 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16  Next
 Post subject: Re: 1972 H1-B
PostPosted: Wed Sep 18, 2024 10:27 am
Went back and set my timing, seemed a little sluggish, I set it at .126 BTDC, had to use my calipers, didn't have a dial gauge, seems to be more responsive now, might pick up a dial gauge at HF just to double check.
PostPosted: Wed Sep 18, 2024 11:04 am
How about a view from the left side.
PostPosted: Thu Sep 19, 2024 7:55 am
https://www.facebook.com/groups/3952323 ... &ref=notif
PostPosted: Tue Sep 24, 2024 1:49 pm
Update: After putting about 25 miles on it, the bike seems to be running great, only problem I have found is a couple drops of oil under the injection line where it connects at the LH cylinder. Need to figure out if it's the washers or where the line screws into the fitting.
PostPosted: Fri Nov 15, 2024 12:42 pm
Is there anyone out there that rebuilds the injection lines?, I know there are rebuild kits out there but would rather let someone with experience rebuild them.
PostPosted: Fri Nov 15, 2024 4:35 pm
Yes Ade Critten in the Isle Of Man rebuilds them
You can whatts App him on +447624 478353
PostPosted: Sat Nov 16, 2024 9:31 am
Thanks, Scouse, good to know but looking for someone in U.S.
PostPosted: Sat Nov 16, 2024 4:50 pm
What got my attention on the oil lines, I let the bike sit about 2 weeks, when I cranked it up, I got heavy smoke out the left exhaust for about 2 minutes. I'm not sure if I have a weak spring or a leaky valve. I had a mark on the clear oil view hose on the oil tank, didn't seem to have lost any oil out of the tank, don't need a leaky valve and have an oil lock.
PostPosted: Sun Nov 17, 2024 8:40 am
You can test for leaking valve by hanging it by filling it and then hang it from the case banjo overnite. If it drips, then it needs attention.
New springs and balls are on eBay... it is an easy fix for H1B.
PostPosted: Sun Nov 17, 2024 9:38 am
Thanks a million, Mraxl, I didn't think about hanging it up, will give that a try, I'm definitely going to rebuild them for peace of mind.
