It is currently Tue Jul 08, 2025 11:38 pm
PostPosted: Thu Oct 06, 2011 2:13 pm
kas750 wrote:
I use petrol in an atomiser and a 1" brush.It works well.
Sounds dangerous!
PostPosted: Thu Oct 06, 2011 2:34 pm
Only if the engines running or you are using a blow torch in the same enclosed space. :lol:
PostPosted: Fri Oct 07, 2011 2:25 am
good job you don't have a lighted 'roll up' hanging from your lip too Adie :lol:
Comfortably Numb :o)
PostPosted: Sun Oct 09, 2011 6:43 pm
Wire brush followed by brushed of coats of Evaporust worked very well.
It's not great but is much better and I ran out of daylight.
Falcon; no problem with wheel removal but not worth relacing the hub with these spokes and rim (for imersion and blasting)
I have an aluminum rim with decent spokes ready to go on this winter but thought I'd wear the existing tire down some more.
Then again, this could be an excuse to buy a small media blaster and use up some walnut shells or maybe even try some corn cob media!
PostPosted: Sun Oct 09, 2011 7:02 pm
Im a "toothbrush and simplegreen" guy myself.......
PostPosted: Sun Oct 09, 2011 7:20 pm
No wonder your teeth always look so white.
PostPosted: Sun Oct 09, 2011 8:28 pm
Both Steve Chandler and I had some aluminum stained by Simple Green.
Probably cause it got missed by the wipe rag.
I'm guessing you haven't had this problem.
PostPosted: Sun Oct 09, 2011 9:11 pm
I don't care who u r that's funay. :lol:
PostPosted: Mon Oct 10, 2011 5:11 am
olde coney wrote:
Jim, I reckon that soda blasting is the best option
see this DIY equipment
http://www.youtube.com/watch?v=YI_Bnl6l-OY
I haven't used it myself but I hear that it does work and the soda isn't too aggresive on chosen parts
Good luck, as John already said the only way is to disassemble the hub, but this may be a temporary solutiuon :thumbup:
I had good luck with that system:
1974 H1
