It is currently Thu Oct 31, 2024 7:58 pm
 Post subject: mystery electrical part
PostPosted: Mon Oct 31, 2011 9:27 pm
this part was in my original wiring harness.
it was between the regulator/rectifier and the battery/fuse. I don't see any reference to it in the electrical schematic in my shop manual. Any idea what it is? Is it needed?
'72 h2
Jason
72 h2 in a 93 Katana
03 cbr600rr
80 kz750 ltd
94 pw50
PostPosted: Mon Oct 31, 2011 9:33 pm
'72 h2
It's a reverse current blocking diode. The early H2s needed it because the regulator would drain the battery slowly without it. Later regs behaved better and Kaw dropped the diode.
PostPosted: Mon Oct 31, 2011 10:41 pm
To add to Jim's post, they weren't factory installed on the very first H2's, they were supplied by the factory for bikes in service before a frame number that they came already factory installed on.
There may be a FDM for it in mraxl's resources.
PostPosted: Tue Nov 01, 2011 2:38 pm
Well, that explains my mysteriously draining battery too..
Man, I must have a really old one!
Jason
03 cbr600rr
80 kz750 ltd
94 pw50
PostPosted: Tue Nov 01, 2011 2:56 pm
I'm pretty sure all '72 H2s had the less desirable regulator, and maybe the '73s too.
PostPosted: Tue Nov 01, 2011 4:17 pm
Both my '72s have that thing. One very early, one very late.
PostPosted: Tue Nov 01, 2011 5:03 pm
My early '72 (6300ish) did not have it from the factory, I learned first hand why those were needed asfter a few months. It wiil discharge the battery in a few weeks. Installed the rectifier and battery never goes down.
PostPosted: Tue Nov 01, 2011 5:19 pm
The service bulletin answers some questions:
Quote:
Bulletin#: 73 H-9
Date: May 17, 1972
Bike(s) affected: H2
Subject: H2 rectifier
Action taken:
An H2 not driven frequently may discharge the battery, because of a slight drain on the battery from two small resistors. A supplemental rectifier has been developed to stop this leakage. The new part, part #21061-014 must be installed on H2's through H2E-13265. H2's H2E-13266 and up have this installed from the factory. (It is installed between the red lead from the regulator and the battery.)
