It is currently Mon Jun 16, 2025 8:44 am
PostPosted: Mon Jan 28, 2019 9:39 pm
Agreed, Tim is the guy to talk to when I need to try it.
PostPosted: Tue Jan 29, 2019 12:53 am
Thanks guys!!!
PostPosted: Tue Jan 29, 2019 6:33 am
An alternative is to use dry ice.
Results vary depending on metal thickness. Won't work well with OEM mufflers.
PostPosted: Wed Jan 30, 2019 8:14 pm
I have also done this. I left the stinger end uncapped. It worked pretty good. Split one pipe but I think some of the metal was thinned out from grinding the street too much. Easy fix with the welder.
PostPosted: Tue Feb 05, 2019 3:09 pm
The high temp today was 69 degrees. I took advantage of the break from winter and prepped the FPPs for the application of Wal-Mart's best Rustoleum high- temp satin bbq paint. They turned out pretty good.
PostPosted: Tue Feb 05, 2019 10:30 pm
Them'r some bad-ass looking pipes.
PostPosted: Wed Feb 06, 2019 12:12 pm
I really like them on the RZ. Not so much on a Triple. The Denco is a much better Triple Chamber.
PostPosted: Tue Feb 12, 2019 7:03 pm
Pipes re-installed. Packing courtesy of MP Iron Brady augmented with Lowe's finest aluminium insulation tape. Safety wire wrap will follow and then the cans.
PostPosted: Sat Feb 23, 2019 11:07 am
Hey Tim, how did that insulation work out for you?
PostPosted: Sat Feb 23, 2019 11:17 am
Hey Ol Podnah. It works great. 2nd time I have used it. I still have enough left for one more repack on the RZ. Thanks again!! :thumbup: :thumbup:
