It is currently Wed Apr 30, 2025 1:27 pm
PostPosted: Mon Jan 03, 2022 3:46 pm
I need this engine gone. I have the H1B project pile exploded all over my garage, and need some $$ for parts.
I have an RD250 engine left over from when I had a bunch of Yamahas. It is built on R5 cases, with an RD250/350 6-speed. I’m sure the crank was a used one when I built the motor but that was a while ago. New crank seals. Top end is stock bore with new Yamaha pistons, rings and small end bearings. All covers are included, there is an alternator rotor but no stator. Injector oil pump is inside the cover.
I’ve never run the motor. I haven’t had an RD for a while to try it in.
I’m not gonna deal with shipping. Local pick up or I can meet a buyer for delivery within reason, or deliver to the Deals Gap 2-stroke meet in May if you’re not in a hurry.
Mark
Mhbadger@yahoo.com
Obstreperous stink wheels!
1975 Yamaha RD350
1975 Yamaha TZ750
1980 Moto Guzzi SP1000
2019 Triumph T100
PostPosted: Wed Jan 05, 2022 3:04 pm
Can I pick it up at the Gap?
PostPosted: Thu Jan 06, 2022 11:10 am
Yes you certainly can. I trailer my bike over so it isn’t a problem.
Mark
1975 Yamaha RD350
1975 Yamaha TZ750
2019 Triumph T100
PostPosted: Thu Jan 13, 2022 2:20 pm
sweet, you going to upgrade Carl? i was debating buying this but, I have plenty of rd stuff, get on it!
PostPosted: Fri Jan 14, 2022 3:41 pm
Yep, I think I am going to upgrade a DS7 with disc brakes pipes carbs and some porting.
PostPosted: Tue Apr 12, 2022 10:29 am
I hear ya.
btw i have that seat pan off mine. its not bad but not perfect few pinholes in it but solid. still want it?
aaand if you are looking to get rid of those 26mm carbs on the ds7 let me know i could use a spare set $.
PostPosted: Wed Apr 13, 2022 6:16 pm
Just a note on these engines, the 6 speed RD and TZ transmissions will interchange, as will the TZ dry clutches, air cooled 250/350 top ends, and, TZ liquid cooled 250/350/700/750 cylinder/head/pistons. Very workable engines.
